7745 no clutch pressure
reco31
reco31
A problem that has gotten progressively worse, now when the clutch is depressed sometimes the tractor continues moving. Wondering how to check fluid level (location??) and cylinder condition.
The clutch shares the brake fluid reservoir. There is a section in the centre of the tank which feeds the clutch. The reservoir is under the bonnet at the rear of the engine at the back coloured white, plastic.
You will probably have to bleed the clutch system after you have refilled the tank with brake fluid, then clean the master cylinder surrounds and the slave cylinder to check for any leaks.
Dave
