8011 Clutch Adjustment
taviarankin
Tav
Hi Guys,
Im hoping in all the knowledge you share someone might be able to help with clutch adjustment instructions /diagrams for a Zetor 8011 2 Wheel Drive (If that Helps)
Thanking you in advance
Tav
There should be 30mm free play on the top of the pedal, thats the distance the pedal moves before any resistance is felt.
This is adjusted by a bottle screw on the linkage to the left of the gearbox under the cab floor. You will need either 2 12mm or 13mm spanners, one for the bottle and one for the locknut.
