8011 crystal hydraulics
tonyzetor8011
tonyirl
hi, i was going to buy a hydrolic/power link box for my 8011 but someone says it might not work as it only has the lever to raise the arms first then it will engage the linkbox. the tractor is old so i am not really sure what levers does what, but just wanted to know if there is a lever that will engage the linkbox on its own or do i have to raise the tractor arms first.
the Crystal came standard with the external spool valve to control the dump box independent of the 3pt. No problem.
next to the 3pt lever. 3pt has a square knob, external is the inward lever, with a round knob, if my memory serves me well..
The inside lever on the quadrant is for external services, lever is back for single acting services pumping , forward one, where the lever will stay, to hold, foreward again to drop or float and all the way foreward to use the other service tapping for a double ram or another single ram. It's a pretty good versatile system.
external rams have priority over lift arms
