8011 zetor
gwanny
gwanny
hi out there in zetor land this loader is a real pain does any one know where i can run my return to tank hose from my loader controls i found only one plug at the very back just under my remotes are there any closer then that
My 6745 has had the gearstick housing drilled and tapped to take a 20mm return line. This is one solution, and seams to work ok.
Otherwise the filler plug can be drillet to take the return.
As far as i can tell the only factory return is via the external curcit quickfit conections, but these are 2 way circuits so are only able to be used as a return if the external controll leaver is in the corect position. Hence i am not using them for my loader
I used the oil drain hole on the rear axle of my 6245 for the return line of the loader and took the pressure from the plug on the pump plate on the bottom of the rear axle as well. You have to have the remote lever locked either fully forward or backward to get pressure at that point, but it works well. The holes are metric but bsp fittings will thread in well enough with a little effort and some sealing compound.
Paul.
