My 8045 is leaking from under the center housing
anyone had leaks in that area
its been too cold here to work on outside
-20 right now been as low as -38
thanks for any help
Sorry for delay
Can be either the pressure pipe from the main hyd pump leaking or either of the seals on the gearbox input shaft would be my initial guess, so remove the cover that has the shifter lever on it under the floor on the left side and see if you can see where the oil is coming from. It should be quite obvious with that amount of oil leaking
