8145 Spool Valve
jf850
jf850
Hello all.
I have a 92 regd , but I think actually 89 , 8145 with the standard Zetor cab. Also have an Earlier 12145 with a Duncan cab.
Recently the 8145 developed a serious oil leak under the floor, oil dripping off the left hand back axle. Discovered the Spool valve handle on the left hand side had fallen off. there appears to have been either a key out through this , or a roll pin. There are 2 different size O rings on the valve piston. It has a square flange machined at the front.
Has anyone had this happen their tractor ? What do I put in this small hole to keep it in ?
TIA.
