8441 pto issues
keithclendennen
Keith C.
I have an 8441 that has less than 1100 hours on it. I use it mostly to cut and bale hay. This past fall as I was finishing up baling, I noticed a distinct smell of the clutch burning, and it seemed to be the most intense right under the driver's seat. When checking I noticed that the hand lever cable for the pto clutch still had alot of slack in it when released. I disconnected the linkage under the tractor and could not budge the pto clutch arm by by hand, but I could take a hammer and tap it forward. I reassembled the linkage and did the same thing, which took the slack out of the cable. I have not had a chance to try it yet (still a sloppy winter here in texas), but I summized that the pto was not fully engaging. Could this have been my problem? If so, what do I do to loosen things up? Thanks.
Thanks. If the pto clutch is trashed, what is involved in replacing it? Do I have to split the tractor to repair it?
It sounds like the crosshaft for the release fork is siezing. You could try greasing it but I think you'll have to split the tractor to free it off properly. You can replace the plate/s when it is split.
Thanks. That is what I was afraid of. Is this a common problem with Zetor tractors? I would think the hours on mine would be relatively low compared to some of the others I have seen here? I purchased it new and was expecting much more service out of it before I started to have problems.
The pto clutch plate usually out lasts the tractor,your just unlucky it wasn't getting fully engaged.
