9111 Wiring?
mike
Mike 9111
Hello to all on this website,
Recently we bought a 1988 Zetor Crystal 9111. We're really pleased with it. Ive worked round and with zetors all my life but this it the first crystal we've had. Its a 40km model and i want to use it for road work, but i cant get the side lights to work. Are there any common faults with these ian overlooking?
Cheers,
Try to replace fuses in the right fusebox. I think it is 4th and 5th fuse from left side. If the lights are will still not lightining open the little quare box in the floor. It is left to the seat. You have to remove floor rubber first. In the box are cables to the lights. Disconnect the cables (I dont know which is it, but you will find it by color), clean the terminalboard and connect cables again. I am using WD40.
Greets, Miro
