I have brake problems. To stop the tractor, you literally have to stand up in the cab and stomp on the pedals. But if you hit the pedals to hard, then the tractor does not want to move. After letting out the clutch, it acts like something is holding it back. Then if you press in the clutch to shift gears, the tractor stops in the middle of the road. The brake fluid level is high, where it is supposed to be. Any ideas? Also, it probably blows 1 AC fuse every 3 hours of use. I do not have the AC on high, just 2nd speed.
