9641 forterra
4
4wd
Guest
Not much discussion on the more recent models on here.
Just wanted to sy I think the 9641 Forterra we got a couple of years ago is a solid reliable tractor.
Hearing all the complaints about numerous glitches wih JD, case et al, how refreshing that the worst thing to go wrong with ours so far is one brake light went off - found to be a bad connection, it didn't even need a new bulb
Topping last week.(Twose topper)
Have been baling hay the last few days, too dusty for cameras!
Baler is a Krone KR125.
Nice picture,looks a bit like Dartmoor/Exmoor by the background.
I agree there is not much discussion about newer models.Probably because people only find their way here when they are looking to solve a problem or more usually,they have just bought their first Zetor and don't know how to operate them!
You should send in reports occasionally on how your tractor is going.
When you run your 9641 with a load on it, where does the temperature gauge read? I just got a 9741 and mowed a bit with it last night and the needle on the gauge stayed in the hotter side of the green, close to yellow. I don't know if this is normal or not.
Thanks for any info you can provide!
