My power steering on 7745 seems lazy to say the least. For example when the tractor is standing (not moving) in a clean concrete slab, it is difficult to move the front wheels to either side.
When turning the steering wheel, I seem to hear a screeching sound coming from the steering pump. I guess it is oil relieving through the relief valve in the pump.
Is it possible to adjust the relief pressure in the relief valve, by adding a spacer to close the spring more or by adding a stronger spring?
Secondly, assuming I could do either of the above two options, could there be any downside side effect
Thanks for any advice on this matter.
R
R
