Hello.
I am a 16 yr old zetor enthusiast i own a 3545 which i am restoring and i drive a 7045 some days. now renze are the front swivel seals fro the 3545 like roadless tractor ones??? can anyone please help as i am getting desperate
What are the swivel seals, help me with the translation please ?
Do you mean the dust boots around the driveshafts ??
I think you can get universal dust boots at an automobile parts supplier which in most cases, will fit.
If you need the oil seals, they are standardised according to ISO or DIN, any good industrial parts supplier must be able to order some oil seals.
hi Renze you know on the 3545 on the front axle were the hub is you have the swivel seal this is held together through 3 metal plates which are sandwiched toghether with lots of small bolts. ( in other words the seal which goes round the shinny ball on the axle) are these the same as roadless ones??? thanks
Its called the "scraper seal" I think. it just cleans the "ball" before it goes into the hub. You can get them from Alan barlow i I suppose- (01625) 422489 dont know his email
