- Joined
- Mar 17, 2004
- Messages
- 23
- First name
- Mike
I've been having problems with my alternator and now the battery is running down. After checking, alternator is barely generating charge. (Time for a rebuild.)
Guess I should look at getting a 70 amp instead of 55 amp.
But what may be of interest to some, even after recharging the battery and adding on power boost of 600 amp crank charge,
the motor started for about 6 seconds then just died.
Tried to turn it over again but it seem to be jammed.
First thought was starter, battery, grounding problem, broken piston, etc. etc.
After a few hours of frustration, I just kept pressing the starter then after almost 30 seconds she finally started up with what seemed to be a couple of gallons of water spitting out the muffler.
We had severe rains and since the tractor is outside, guess the angled muffler just wasn't able to deflect the rain thus the water in the muffler and looks like its mixed in with the engine oil.
Time to change oil anyway.
Now I have a tin can over the muffler.
Guess the rain got in and put added compression on the engine making it seem like it was ceased.
Someone mentioned to me why not drill a 1/16 inch hole in the bottom of the muffler to let any water accumlation out. Does seem to be quite rusted at the bottom so it might not be a bad idea.
Appreciate comments from the PROs. I'm somewhat reluctant to drill - but if has no impact, I'll go for it.
Also, this is the second alternator repair in less than a year. When I bought the 7745 in April/04, the dealer said it had battery drain and sent the alternator off to be rebuilt. Problems started with battery drain again mid-July 04. Any suggestions on what the problem could be.
Tests now show about 12. 5 amps on battery, at starter and at alternator. Could defective alternator drain battery? Any thoughts!
