Blowby
baron
Baron
I have recently bought a 5211 zetor that seemed to run rather well. After a couple of weeks I noticed it was using a lot of oil and water. Never over heating. With blowby will you loose coolant also? Could it be sticky rings or is it just worn out? The Diesel engine has all kinds of power. First time with a Diesel engine. Unsure what to do or where to begin. Any advice would be appreciated
It is unusual to hear of a 5211 to be porous, but as it has individual cylinders it's easy to do the engine, If your losing water check the head gaskets or liners. burning oil sounds like you need a overhaul.
