My 7341 has sprung a fluid leak from one of the components above the compressed air tank. I'm assuming it's something to do with the air brake system and that what's leaking is brake fluid, because the pipework connects the air tank to the leaking component. From reading around I'm guessing that the component might be a "fluid reaction vale".
Questions:
- Are there known failures of these components or should I be looking for leaking joints either side?
- Are they generic components that any agri dealer might stock, or Zetor specific?
- Since I don't need air brakes, is there any way I can disable the circuit temporarily so that I can use the tractor without gushing fluid wherever I go?
Any other advice weclome.
Questions:
