brakes
robert_young
Robert Young
I need to replace a rear wheel cylinder on my 7441 proxima.I was hoping I could get at it by removing the seat and there would be an access cover I could remove to get at the cylinder. The tractor has a cab on it. It looks like a bugger of a job if there is no access hole.
There is a small hole for bleeding the brakes,not big enough to work thru.
Thank you for any advice you can provide.
Robert Young
7441 disk brake slave cylinder should be accessible from the back, under the plastic cover.
