Buying 11441
billy52
BillyIreland
Hi, This is my first post.
I'm going to buy a 11441. Please give me your opinions on them and you experiences with them. The dealer told me their 115HP turbocharged 4 cylinder. I will be using it on a 4 furrow plough,2300 slurry tank,18ft silage trailer,10ft mower,16 ton dump trailer.
Will it be fit for this work?
Thanks!
good tractor With a bad engine characteristic. it has a wery bad turbo lag, wich mean its dead in the water below 1500 rpm. and this lack of Power means you will wear Your clutch out faster when trying to ease away With loads. it gets a bit better when you Block EGR but its still not good. i know renze is trying to figure out if a turbo from a 122441 will Cure the problem, wich i think it will. also the 11441 has a Liquid to air intercooler wich is more ineficient then a air to air intercooler. ive had one for several years and traded it for a forterra 135 and now i have a 140 hsx. and the engine in the 11441 is unique in the zetor Portfolio in lack of Power under 1500 rpm.
I would recommend a 10641 or the Forterra 125.
How much power has a 10641, will it still be able to do these jobs
I don't understand how Zetor made such a big mistake when they were making the 11441!
