clutch bleeder nut location 5211
jwg53
birddog
Where do I find the nut to bleed the clutch. Master went dry and is full of air and I need to bleed to get my clutch back up. Thanks for the help . 5211 tractor
At the slave cylinder. Its on the left side under the tractor, it points down 45 degrees and is mounted to an arm which goes with a shaft into the clutch housing.
