Clutch Bleeder Valve for Zetor 5245
shereiner
Shereiner
Having difficulty getting 5245 into gear. Believe it has air in lines. Where would the bleeder valve be located for the brake/clutch cylinder? Under much snow and hoping for help soon... Thank you very much!!
hi great site can you tel me how to get on agmachinery talkshow thanks
Johnny koller could you please use Google to find the heap of machinery talk sites, and stop posting the same irrelevant question dozen times ? Thank you.
First check fluid level in the reservoir, the clutch res. is the small tube in the centre of the bottle.
Bleed screw is on top of the slave cylinder located on the N/S , partly behind the battery box.on the side of the gearbox / clutch housing. Hope this helps, Dave
