Hello.
I have a Zetor 6341. It won't go forward or backward. Fluid levels fine. Can you adjust the clutch or does the master cylinder or slave assembly need to be replaced?
Give us a few more symptoms. Will it go into gear without the clutch down or does it grind. Just wondering if you've broken a halfshaft or sheared the crown wheel rivets, try moving with the diff lock in.
