- Joined
- Aug 8, 2010
- Messages
- 3
- First name
- rangerintexas
I was using the 7321 to move some dirt. While in a forward gear I heard some kind of rattling noise for a short distance. Next time I pressed clutch it went all the way to floor and did not disengage. Tractor kept going - I had to shut off engine to stop the tractor. I looked at fluid resevoir and it was empty.
Clutch pedal just falls to floor with little pressure.
Questions:
What type of fluid should be put in brake/clutch resevoir?
Also, filler cap is practically impossible to get to without removing
top of hood. Am I missing an easier way to put fluid in reservoire?
What should be done in troubleshooting problem?
Thanks for your help with this problem!
Questions:
