Clutch problems HELP!!!!
farmerbrown
Farmerbrown
Hi every i bought a zetor 6245 and the clutch has been frozen up so i bought a brand new zetor oem clutch and put it in and also changed t/o bearings. The problem i have when i put the new clutch it the flywheel and bolted it fast it shoved the fingers completely up and didnt notice until tractor was completely back together and went to start it and the t/o bearing doesnt even come close to hitting the fingers i dont understand any help wuld be appreciated thanks andrew
Adjust the tie rods on the outer end of the pressure fingers. I have no idea what the exact measurement should be, i allways measure before pulling it apart.
See the thing that i have thought about is when i got the new clutch i put the new clutch pad with fw and then inserted the hole clutch packet and put all the lil bolts bac into it. Now when i got the new clutch it had spacers under three fingers to take the presssure off so u can get it bolted eaiser. Now when i bolted it together it pushed the fingers towards the center like its always depressed. The adjustment bolts on the fingers shuld have the fingers almost touching the clutch correct? But when i put it together it pushed them way up into the air. Mabe this will help make it easier to understand thanks
