CLUTCH REFIT
a5718ireland
ireland
Zetor 5718
im refitting the engine to my 5718,im not to sure how to set up the dual clutch,any tips?also when replacing the thrust bearings do they need greased?help!
You should put a little copper grease on the shaft (were the bearing slides) What is the problem you are having with the clutch?
The settings for the lever heights are : Main drive: 21mm, PTO levers: 33mm. This is measured from the flat surface of the clutch (the one the fixing bolts go through) to the tips of the fingers where the thrust bearing pushes on. Regards Mike
