I HAVE a 6341 with 750 hours and the clutch is slipping when under a heavy load pulling a pasture renovator.
The owners manual said could be the clutch petal needs adjustment. There is no free play in the petal. Just a small push down will disengage the transmission and you can shift easily. Is this a worn out clutch or is there an adjustment to the clutch or the petal?
Any info will be helpful
