compressor zetor 5718
lingerin
lingerin
Hi everyone!
I am knew to this page along with my "new" zetor 5718 -1977...
I have a problem when trying to get the air-compressor to work...It seems that when I start it it begins pumping diesel out of the hole where I should take the air from. How is this possible??
Where does it leak diesel into the compressor ?????
Easy to fix or not ??
Thanx in advance
Regards Jrgen
Hello,
How much diesel is coming ? Only when you first started it after 20 or so years, or does it still throw diesel after a while of use ?
Maybe someone put the fuel in the compressor against rust ?
remove it! you dismount it and put a mask Ever seen gas oil to communicate with the Compressor! your filter flees t' it?? Not known by on our premises afflicting
