Convert 9111 to 4WD
The whole thing would depend on if the housing mounts will fit your Crystal as the steering ram is different on a 9540, you will still need the parts that engage 4wd that goes onto the back end as they are different as there was a disc brake on the drive shaft on 9540 plus you will need the gears in the back end.
Is it the 9540 that's on done deal for sale for parts?
You will have to see if the mounts are the same as your Crystal to suit bolting to the engine, and if the radiator mounting points are the same. Also the power steering is different unless yours has an orbital unit.
