Our 7245 front pump only uses 4 m12 bolts on an L shaped bracket, with an off the shelf plastic slightly flexible coupling and a flange turned down to fit the pulley and bolted onto 4 tapped holes in the pulley. Its not a
Zetor conversion , it was made up by a dealer called Morris Corfield.
It gets its oil from the bottom of the 4WD housing, has a gauze filter on the suction side and returns to the
hydraulic trailer brake servo. The pump plate is not off a 7245 but a 6945.I can't remember the reason for this, but I've got a 7245 pump plate complete with pump, only done 50 hrs if anyone wants one !!
Here's a couple of poor pics of the "new" pump and filter, been on now for 4850 hours.
<a href="http://s140.photobucket.com/albums/r13/dpeters_01/?action=view¤t=7245hydpump.jpg" target="_blank"><img
<a href="http://s140.photobucket.com/albums/r13/dpeters_01/?action=view¤t=7245filter.jpg" target="_blank"><img
<a href="http://s140.photobucket.com/albums/r13/dpeters_01/?action=view¤t=7245.jpg" target="_blank"><img
Tractor has beem topping all day, and has an oil leak somewhere on the compressor, so its dirtier than usual.
