diesel in oil!
nils
Nils Arne Opsund
I just bought me a zetor 6045 84mod .After an oil shift and 2-3ouhrs driving I chek the oil again-suddenli it was 19liters on the motor-it chud be 12liter. I think it is diesel in the oil!Where can it come from? it is not from the hydraulic steering,and its not water from the radiator!Can it come from diesel inj.punp or other places? engine has running 2200hour amd going fine,no black smoke!???
I suppose, with the fiber ring replaced in the 5245's fuel pump, that also cured the high oil level in my 5245..;)
I had the exact same problem with my 7245 last year. The solution was to get the injectors cleaned up. one of the injectors was not 'spraying' as it should and the diesel was going into the sump. That solved my problem
hello zetor "s! The injectors was fine ,but one of the push rods was crooked like an S! One valve was no opening,so the engine was going on 3 syl,and the diesel was going to the sump, now the engine is ok!;:p
