double clutch problems
kalkveien
Kalkveien
On my 5511 it is a handel under the dashboard to select 2 types of settings of the clutch engage. In one setting its suposed to only work on the gears an the other setting on the gears and pto together.
It dosent work on the pto. Is it somting wrong or is it just a adjustment? Is it posible to make a modification and make a seperate pto handel like on the 6245?
No, for independent clutch, you need to install an extra lever and throwout bearing..From a 5711 or 6711. I dont know if it has the hole for the extra lever going into the transmission.
