About every month or so my 8540 is draining its battery dead overnight. A heavy drain short with no ignition switched on.
I recharged the battery and when I reconnected the negative it sparked a little which indicates the frame is live with no ignition?? Any pointers or analysing checks that can help identify the fault would be appreciated. ps I have checked wiring etc so assume it is either alternator, starter motor or cold start regulator based??
