Hello.
engine rocker cover gasket split after 250 hours . shuttle lever developed alot of freeplay hard to know when in neutral position . anybody have similar problems on 6441to 8441 series?
proxima loves to split there rocker cover gaskets dont know why but once you change it it seems to hold as with the shuttle lever maybe th bolt that holds the selecter lever in place has come loose good luck
