Hello.
AFAIK all gear ratios were identical, the difference in 25 and 30kmh was made by fitting 4511 portals (that ran 25 on 14.9-28 rears) and a 4wd dropbox gear with 40 instead of 41 teeth so the front axle gears should all be the same.
the 25 and 30 front Axels are not interchangeable. you cant fit a 30 kmh to a 25 kmh tractor and vice versa. I have this from the importer here in norway. som have tried to but does not work.
