Front end Loader Issue
txrancher
TxRancher
Front end loader on my Proxima 100 will raise the arms, and will raise and dump the bucket just fine, but won't lower the arms. Will appreciate any thoughts!
as the bucket is working its got to be the slice of the spool valve that controls the arms aint working.
is it electric or cable controled.... if its electric probably a duff solenoid or a wire broken,
Appreciate it, however, I discovered last night that lowering the arms on the FEL wasnt the only issue... the arms on the 3 pt lift won't lower either. So, front and back will both lift but neither will lower. Is there a switch or valve somewhere that will release the pressure? There is a valve under the seat on my JD 1530 for this purpose. Is there something like this on a Proxima 100?
there is a valve mounted on the hose for lifting the front end loader on mine with trac lift loader. i once closed it by mistake and could not lower the fel.
