- Joined
- Feb 13, 2024
- Messages
- 95
- Location
- Windsor Vermont
- First name
- Robert
I greased my Zetor 3340 and I began at the front of the tractor.
I liked that all these grease zerks had grease zerks caps on them too.
1st front axle King Pins (4 grease zerks)
2nd front axle Pivot Pin (2 grease zerks forward and back)
3rd 4WD Shaft Couplers (2 grease zerks one forward and one back)
4th Clutch Shaft (2 grease zerks one left side and one on the right side)
Note: I am not sure what these 2 grease zerks are doing,
but I gave each one about 4 shots of grease,
as there was no way of knowing how much grease is needed for them.
My thinking is, 4 shots of grease should be safe to do for the Clutch Shaft.
5th There a 3 grease zerks at the back of the tractor with the 3-Point-Hitch.
6th I also greased the Loader which had 16 grease zerks with no grease zerks caps.
I may get some and add them to the loader.
