heater and radio not working zetor 7441
gregkelly
tarmonman
hi guys have a two year old zetor 7441 and the blower in the heater and the radio have stopped working . havent a manual so i changed all the fuses in the cab to the left and right of the stearing wheel and that did nothing . i think it must be a fuse . are their fuses for both the radio and heater under the cab? its annoying me as i neither have a radio or heater , can anybody advise please . thanks
I don't have a radio, but once the heater in my 3340 stopped. I checked the fuses and they were all ok. It turned out to be a loose connection behind the fan switch in the overhead. When I lowered overhead cover, the fan would go on and off. After I tightened the loose connection, the fan has worked just fine.
There is a block connector near the heater under the roof which could be loose. Lift the roof at the front end by undoing the 4 - 13mm headed bolts and propping it up with a 18" long block to get access.
