Help me to lean to use a Zetor 3011(new into tractors)
zetor3011dk
zetor3011
Hey Zetorfans
I am abort to go and check out a Zetor 3011, but I do not know anything about tractors, can you help me???
I would like to have, not a hole manual , but only a view over all the different things (buttons, pedals, how the shift works an so on . .) you have in front of you when you are sitting at the steering well.
Mick Denmark
Use the search engine at top of page and type "hyrdaulic levers"
This will get you started on how to use controls.
Thank you for your answer.
But i still would like to have, not a hole manual , but only a view over all the different things (buttons, pedals, how the shift works an so on . .) you have in front of you when you are sitting at the steering well.
Mick Denmark
your gears work 1 3 5
r 2 4
then when you are sitting on your tractor you have to leavers on top of the gearbox
left one is: pto through the gearbox (ground pto) first click upwards.1st click downwards
then neutral is down one click
1st click down from neutral is pto shaft and hydraulic syste,m 540 rpm.
2nd click down( all the way) 540 rpm (engine powered pto)
Right hand side lever is:
up posistion is high range gears
middle is neutral is high and low
down is low range gears.
your hydraulic levers are situated on the right next to your seat.
the lever closest to the seat does spool valves( for use on tipping trailers)
the lever closest to the mudguard is to raise and lower your hydraulic arms. up for up . down for down.
ther is a lever coming from the top cover under the seat on the side. it says: P M S.
p is position control
m is mixed control
s is power control
THE DASHBOARD
you have the throttle which is the small lever coming of the steering shaft. pull to increase the revs! these tractors do not turn off on the key(you must push the throtle all the way back to nothing to kill the fuel to the engine then it will stop).
the button on the top left hand side of the dash is the starter button. this only works if the key in the ignition is pushed down all the way. until it clicks.
the ignition switch is next door to the starter button.
then the fuse box is in the middle.
then horn swithch and indicator rocker switch.
you have the clocks
small clock on the left is air tank pressure( you may not have this on your tractor)
middle clock is rev counter and hour meter is the numbers on the top which count.
then on the right water temp.
i have given you som godd info here.
if you require more just shout!
matthew
