high torque not working on my 8011
bernard
bernard
how much does it cost to replace high torque on an 8011 and how much work is involved
bernard
That depends on what's broken...
Is it the oil pressure system or the brake band..
I assume it is the oil pressure because low torque works fine.
bernard
Bernard,
Start off by checking the Torque muliplier linkage from the lever on the steering wheel and following it down to the gearbox.
Let us know how you get on and we'll take it from there.
TomZ
TomZ
Linkage from torque lever is attached.You can change from low torque to high torque but it slips when under pressure.I have adusted the band but it makes no differance so i reckon it must be oil pressure or pump.
Did you adjust your brake band like this? (Thanks to Crystalman)
Tom,
I was hoping no one would ask that!
1.Drain transmission oil
2.Unbolt brake cylinder cover(Square with 4 bolts and a round lump in the middle of it on LH side of gearbox near the bottom)
3.Remove spring and replace cover.
4.Tighten large adjusting screw with (22mm??)locknut above cylinder cover until it becomes tight and then slacken off 1 1/3-1 1/2 turns.
5.Tighten brake band.There are 3 screws with (17mm??)locknuts.One on each side of the transmission and one on top under the panel in the floor.Tighten each screw until it just becomes tight and slacken off by 1/3 turn and tighten locknuts.
6.Remove bolt on cover on RH side and you can see the torque mutiplier drum.Check that the drum still turns freely.
7.Reinstall spring in the brake cylinder.
8.Replace cover plate on RH side.
9.Replace transmission oil.
Thats the condensed version from the manual .They say you can park the tractor facing uphill and save having to drain the transmission but if you leave the oil to settle and put the good stuff back and top up the rest with fresh oil you will have done two jobs at once!
On a JD they made all this self adjusting,apart from that it is the same! If you ruin a gasket you can make a new one out of a corn flakes packet by scribbling on it with pencil to get a graphite coating-I've had to do this a few times as I doubt if any one will have these gaskets in stock on a Saturday morning!!
Tom
have not tried adjusting it that way ,but will over the next few days let ye know how i get on
