Hydraulic lift quit working on tractor. Lift gradually quit working, not all at once. Tractor is used very little, and has set up a lot. What is the recommended weight Hydraulic oil to use in this tractor? How many different Hydraulic filters are there on this tractor? I have cleaned the magnetic filter under the seat. Does any one have any other suggestions on what else I should check for in the hydraulic system?
Thanks, T
Thanks, T
