Hello.
I have a 6341, the line that runs from my hydraulic pump to a distribution tank keeps blowing the 90 fitting. I've replace the 90 fitting twice this past week with a new one. I think the pressure is too high, is there any way to adjust the hydraulic pressure?
If your pipe comes straight from the pump you have no relief valve in the system before your tank. That's a BIG NO NO !!!
Take your outlet from the spool connections on the rear of the tractor. The relief valve is pre set from new and is screwed in the bottom of the diff housing.
