Hi!
Zetor 8011 -73.
I have hydraulic problem again. I thought i had an "air lock" as you have explained earlier. I filled up oil(gear), I parked in a steep hill and opened the banjo nut. The hydraulic started to work again but soon it stopped again. Then, i tried this:
There are two levers to the right of the chair(connected to hydraulics over the rear axle). The one closest to the chair should normally be in the rear position to make the hydraulics to work. Now I have found out the following.
If the hydraulic does not work and I move the lever to the front position and then back to the rear position again, the hydraulic starts to work again.
Are there any valve connected to this lever?
Can I, in some way, adjust the valve?
Or do you have any good ideas?
Ragards, Hans
Zetor 8011 -73.
Ragards, Hans
