I finally found after many years of slow and weak hydraulics what was causing the problem
The steel pressure pipe from the pump that goes up past the diff to the top the block , was damaged and had a split in it , So has slowy being getting worse over the yearsuntil finally gave up completely
My question is do you have to take the diff out to be able to replace it , as I am struggling to get the new pipe in , We got the old one out ok by cutting it , but can't seemt o get the new one in .
I think we need to take out the diff which would make it easy to reaplce but wondered if anyone else has had the problem and how the managed to replace the pipe . Obvioulsy if I can avoid taking out the diff I prefer not too.
