Hydrostatic steering
charretier
charretier
Hallo, I have 14245 Zetor and have a problem with de steering.
Can somewone tell me what shoud happen.
If you turn to the left no problem but to the right it sometimes blocks en you can't turn to the right.
What could be the trouble.
Thank for all infomation given
Eric:):)
Used to have exact same problem on 7745. Did everything possible to cure the issue, from changing oil and filter in system, to full check on all steering system assembly from steering wheel to front axel, to replacing seals etc, on the power steering ram, to replacing the damper ram up front. Nothing made a difference.
Finally, I just adjusted the relief valve in the power steering pump. Bingo, problem solved.
I say go for it.
