question I am thinking of buying a new Zetor 6341 Super
C
Chris Beck
Guest
I am thinking of buying a new 6341 4WD. I am not familiar with the Zetor line. Has anyone bought a 4341 or 6341 4WD? If so, are you happy with your purchase?
In the beginning of this year I bought a second hand 6341 from 1998 with 740 hours on the meeter. It is much more modern than the 6245 I had before but I can say it has the good "Zetor feeling". I have the one with only 540 rpm PTO and forward - back gear on separate shift. I also bought a new plough - Kverneland 3 x 12-20 Vario - and it is a very good tractor for ploughing, the engine working good. I have changed the rubberhoses on the suctionline for the hydraulicpump. There was a small leak and the rubber was very hard so I did the job when I changed the oil and filter.
For today Im very happy with my 6341 but I have driven it only about 150 hours on my small fields and a little bit work in the wood. Im just an "moonshine" farmer, working with telecommunications on the days, I have an 14 years old son who drive a lot on the fields and he say he want an J-D but then I say to him - you can buy a J-D when you got money for that, I buy Zetor because then I got most tractor for my money. For the moment here in Finland I think no one sells new Zetors but I think ther will be someone in the future, so today with my experience of the 6341 I will recommend it.
Within two months you can buy the new Zetor Proxima range, i think if you buy brand new, you should at least demo on of these before making up your mind..
The Supers will also get the bigger engine, the 4341 will get a three pot turbo
I bought a new 6340 in 2001 and it is a great machine. We have 20 hectars in a hilly area. This is a stable and strong tractor. We had some concerns if it would pull a 5 bladed ripper and it does with no problem. It is great in all situations, forest, snow, hills, hay cutting...... Only problem I had was the sleeve for the injectors started leaking coolant, relplaced 2 heads under warranty and now more problems! enjoy!
I know a guy that has an MF 3080, a 105 hp six pot ???
Anyway when he bought a 6340 from his brother, he had teh impression that the 6340 would keep on pulling longer than the 3080...;)
