S
sweez
Guest
Hi Folks,
A friend of mine has asked me to fix the electrical "issues" he is having on his Zetor . Since I am pretty good with mechanical/electrical issues and he isn't... Of course I'm better if I have a schematic but he doesn't have one.
The problem is this... His tractor (sorry don't even know model) has 2 fuse blocks. The top has power at all fuses, this seems to run heat, wipers, etc..
The bottom block only has power at the bottom (of fuse. Does all power get controlled by the ignition switch on these tractors or are there relays etc.. in between?
He has no upper cab lights, rear halogen, instrument gauges, etc...
Can I use any old ignition switch (without crank position) will the wiring be easy to match up or do I need one from Zetor?
Thanks in advance for your help .
