Injection pump Zetor Turbo 16045 / Ursus Turbo 1604
toruonlineno
Rustad farm
I've replaced the Injection Pump on our 6 cyl Zetor . The pump has pressurized oil lubrication and automatic "smoke reducing system".
How shall I connect the different lines (lubrication , air etc etc)?
I have created a pdf-image where I have numbered the ports (inlets and outlets) but I can't figure out how to add attachments here.
If you can help me kindly email me at rustadfarm@gmail.com.
Regards from Norway,
Tor
Smoke reducing system cuts the fuel as long as there is no turbo pressure.... But turbo pressure builds because fuel is injected, so the exhaust gases expand from the heat and therefor there is more pressure on the exhaust side than on the intake side.
You should connect it to the intake manifold.
Thanks. Sorry - I didn't explain good enough: What about the other inlets / outlets? Will you kindly contact me, and I'll pass over the pdf-image (or is there some way to upload it here..??)
