Best cure for stuck piston rings due to standstill or extended use at low power:
take the injectors out and split a can of DOT4 brake fluid over all four cylinders. then let it sit for one or two weeks.
Then, cover the injector holes with a cloth and crank it. The piston speed will throw any excess brake fluid out through the injector holes, the cloth is to catch it, as brake fluid will eat its way through paint as well.
You need to make sure there isnt a lot of fluid above the piston anymore before cranking it, as fluid isnt compressible which could bend a piston rod. (phenomena called waterlocking by offroaders)
when the brake fluid is out, put the injectors back, start the engine and gently warm it up. Do not use it hard, as the brake fluid has seeped through, into the
oil sump which neutralises the lubrication abilities of the oil (but cleans crankcase sludge real good)
Then change the oil, run it warm and make it work, give it h*ll.
The miracles claimed by slick50 and other crap you buy at a gas station, are made true by plain old brake fluid.
