- Joined
- Feb 13, 2024
- Messages
- 88
- Location
- Windsor Vermont
- First name
- Robert
Here is my list of oils and filters that I have for servicing Zetor 3340.
Diesel Motor Oil: (if it haves not the centrifuge!)
Fuel Filter:
Power Steering Oil:
Gearbox/Hydraulic Oil:
Portals Rear Wheel Oil:
Carraro front axle
- Shell Rotella T4 15W-40 Diesel Motor Oil,
- 3 cyl. models uses: 2.5 Gallons (9 Liters), 4 cyl. models 3.3 Gallons (12,5 L) - Tractor Supply: 5gals
- Filter: Zetor 77010793 or Wix: 51243 or SANEL/NAPA: 1243
Fuel Filter:
- Filter: Zetor 931260
- Big Rubber Seal: Zetor 931262
- Small Rubber Seal: Zetor 974335 (20x2)
- Glas Pre Filter: Zetor 933221
- Rubber Seal: Zetor 933227
Power Steering Oil:
- Traveller Premium Anti-Wear Hydraulic Fluid ISO 32
- 3 and 4 cyl. uses: 1.5 Gallons (4.8 Liters)
- Filter: Zetor 931154 or older ones 931140
- Big Rubber Seal: Zetor 931155 or older ones 931145
- Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-4
- 3 and 4 cyl. uses: 9 gallons+ (34 Liters)
eg: Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-4 (5 Gallon Pail) | eBay - https://www.ebay.com/itm/333676978297 - Filter:Gearbox/Hydraulic: Zetor 70114566
- Big Rubber Seal: Zetor 70114563
- Small Rubber Seal: Zetor 931136
- Each Wheel Uses: 2qts (1.9 L) Both together 1gal
(may also use: SAE 80W-90 API GL4 UTTO)
Carraro front axle
- Front Axle Differential Housing:
- 85W90 GL4 Gear Oil - Liqui Moly 20016 or SAE 75W-90 GL5 Hypoid LS oil
- Uses: 1.5 gallons (5.5 Liters)
- Carraro Front-Wheel Planetary Reduction Housing:
- Both Wheels Uses: 1.3 qts (1.2 L)
(may also use: SAE 80W-90 API GL4 UTTO or SAE 75W-90 Hypoid LS oil)
