Loader 4320
ken_johnsonlonewolf254
lonewolf254
Need to know where to hook up hydraulics for a FEL on a 4320 with internal hydraulic pump. Know I can tap into existing remotes, but wanted a more permanent attachment. Have found what I believe is power beyond port on bottom of housing under rear axle, but not sure about in and out ports on tractor. Need help !
That is a possibility to tap into the oil pump. However if using that, you do have to block the flow to the 3pt hitch and remotes.
You can do this by selecting a remote, and not attaching a hose to it so the oil is stopped by the coupler.
If you dont do this the oil will run back to the sump via the open center 3pt hitch valve.
