loader promlems
gwanny
gwanny
hi out there in zetorland i need help i have a old 8011 crystail that came with no loader .so i put one on but have no idea how to hook up the hydraulics without using the remotes can i hook right into my main pump line and then let the oil flow threw my loader controls and back to fed my remotes
This can be done fairly simply, but beware that if you use the tractor at high revs for a long time, like foraging, then the oil will heat up quicker.
On the left side of the tractor under the cab on the side of the clutch housing near the back you will see a large banjo bolt on a steel pipe running towards the back of the tractor. remove this pipe and with a 2 wire or more hydraulic hose, run the new pipe to the control block you want to use and back to the point the steel pipe entered the gearbox. you should cover this hose with an anti abrasive sleeve where if goes over the top of the gearbox or clutch housing. It is VITAL that the new spool valve block has its own relief valve set to the tractors own relief valve pressure or you will split the hydraulic pump the first time a ram reaches the end of its stroke. Its been done!
