- Joined
- Dec 12, 2017
- Messages
- 2
- Location
- Maine, USA
- First name
- Ted
1998 Zetor 6341 super
1974 4500 Ford TLB
1969 Ford 4000 3 cyl gas
Log Badger bandsaw mill
I have a 1998 Zetor 6341 with a model 7702 engine. I recently found all my coolant in the base of the tractor. Hoping it was just a head gasket, I started pulling things apart. It is obviously not a gasket problem so I pulled the base thinking it is possibly a sleeve issue.
At this point I have determined that I need a shop manual - which I have now received from Zetor (big bucks!).
After opening the manual, I can find information on the 7701 engine and the 7703 engine but nothing which specifies the 7702 engine. In fact, some of my tractor data is listed under the 7701 heading and some under the 7703 heading. ie.: My injector pump number is the same as that on the 7701 which is the engine in the Zetor 6340 and the injector pump number for the 6341 (which is my tractor) is different from the number on my injector pump.
Also, can anyone tell me if my tractor is a "super"? My tractor is not a turbo.
Thanks for any help .
